grinding noise?
Old Feb 7, 2009 | 01:34 PM
silverbullet01's Avatar
Default grinding noise?
i have a 2000 honda civic ex and when i go to put it in reverse it makes a grinding noise. its a 5spd manual. it doesnt do it all the time but if i try to do it fast it will but not when i do it slow.
Old Feb 7, 2009 | 01:45 PM
It's pretty common, but have you checked the level of the MT fluid? You might also consider draining and replacing the fluid. Use genuine Honda MTF.
Old Feb 22, 2009 | 06:35 PM
finalimpact's Avatar
very much common. reverse is a non sychronized gear set. i always go into 1st and 2nd before going into reverse. doesnt grind at all that way.
vdog
Sep 3, 2005 05:33 PM
bvideto
May 12, 2005 07:53 PM
rex_99civicEX
Apr 18, 2005 11:32 AM
silvercivicsrs
Mar 11, 2005 10:10 PM
foozball
Jun 14, 2004 03:41 PM
