Help 95 auto ex wont switch gears
Old Oct 28, 2006 | 04:13 AM
anonymous4l's Avatar
Default Help 95 auto ex wont switch gears
hey,
i have a 95 civic coupe and the only way that it'll switch gears is if i use a key in the little switch release box. the button thats on the gear shift won't even go in from the park option. but the button moves into any other gear when its not in park. anyone know how to fix this. thanks a lot
Old Oct 30, 2006 | 08:48 PM
D16DAVE's Avatar
Default RE: Help 95 auto ex wont switch gears
it's probaly the brake switch.. this controls the stop lights and the shift lock release.. its fairly easy to replace..or is the battery inoperative as this will also cause this problem..
Old Oct 31, 2006 | 11:13 AM
Hey,
The battery works fine and the car works fine when I stick a key in the lock release and start the car in neutral........is starting the car in nuetral bad? Is the brake switch easy to replace I have the owners manual on disk if so. Thanks again for the reply
Old Oct 31, 2006 | 03:56 PM
D16DAVE's Avatar
check to see if your brake lights work. if not its probaly the switch. if this is not the problem it could be something wrong with the mechanism underneath the shifter cover. if its the brake switch thats easy to replace.starting your in neutral will not hurt anything as it is made to do this.
Koko4
Feb 24, 2013 08:47 PM
alexsi
Sep 7, 2008 05:21 PM
D17Punk
Nov 9, 2007 11:06 AM
SI_smiley07
Aug 10, 2007 02:39 PM
ccarey
May 24, 2007 09:53 AM
