hi folks civic 95 shift linkage and tranny leaking. read more
Old Jan 10, 2009 | 11:10 AM
civicdude95's Avatar
Default hi folks civic 95 shift linkage and tranny leaking. read more
Does any one know how to remove the shift link on da civic 95. im talkin abt the one that comes from the tranny to the shift lever. cause i noticed a leak at the point where the shift link is attached to the tranny. ( there s also a boot at da same location)
My questions are:
I wonder if theres a seal thats worn out
How do i change it if there's one?
thanks, if u need more info please let me know
Old Jan 23, 2009 | 05:09 PM
bmxchickie's Avatar
yes there is a seal there to get the shift rod off you need to punch out the pin that holds it on. there might ce a c shaped clip around it pop it off and you will see the pin. tap it out and it will come off. then you can see the seal behind the boot
poorb0i
Apr 26, 2008 06:18 AM
95h22civic
May 23, 2007 09:20 PM
ngoti 8tor
Dec 5, 2005 10:15 PM
twon
Sep 29, 2005 11:44 PM
twon
Sep 26, 2005 08:55 AM
