Higher speed auto shift.
Old Jul 5, 2006 | 02:48 PM
Melart's Avatar
Default Higher speed auto shift.
My 99 Civic LX has started to shift on the slightest grade at speeds of 55 - 60 mph. It does a down shift one speed and then shifts back up when you level out. It is a very smooth shift with no extra engine revving. Is this anything to worry about and what might be causing it? The car has 125,000 on it. The rest of the time it is normal, at least the way it was when I bought it new. I have always felt it hung on a little long between 2nd and 3rd. Always easy and carefully driven. Thank you for your advice and help.
Old Jul 6, 2006 | 12:05 AM
finalimpact's Avatar
Default RE: Higher speed auto shift.
usually normal.........the transmission just downshifts to attempt to keep the engine in its power band.
James Shaheen
ED-EF Swaps
Apr 11, 2012 06:09 AM
klipschfan4life
Apr 24, 2009 03:25 AM
woburn_civic
Dec 4, 2006 04:41 PM
syrusstephens
Jun 25, 2005 08:45 PM
kjreinha
Mar 24, 2005 03:55 PM
