input shaft
Old Apr 28, 2006 | 10:56 PM
dogma's Avatar
Default input shaft
Hi,
I just bought a 90si, and the input shaft is making noise. I have tried looking for another tranny but can't find one. Has anyone ever changed the input shaft bearing, if so how hard is it?
Old Apr 29, 2006 | 10:51 AM
finalimpact's Avatar
Default RE: input shaft
its a fairly easy job to do as long as your patient and keep track of what goes where. how bad is the noise?
Old Apr 29, 2006 | 11:03 AM
dogma's Avatar
Its not to bad, just annoying when i'm at a stop light. I just can't belive how hard it is to find another tranny for it. My 97 hatch started doing the same thing, and it only took me a couple days to find one on CL.
Old Apr 29, 2006 | 11:29 AM
riceburner700's Avatar
are you sure its the imput shaft and not like a throw out bearing because those make a waterfall like noise when they are going out.... It probably isnt the whole shaft persay but the bearings on the ends.... if it was me i would start with the bearings on both ends and see if it fixes the problem rather than replaceing the whole input shaft and gears/collers/dog teeth/etc.
Old Apr 29, 2006 | 12:55 PM
dogma's Avatar
I'm almost positive it's not the throwout bearing making the noise, because the sound gets alot worse when I down shift. If it was the throwout the noise should be the same, on the upshift, or downshifts.
Old Apr 29, 2006 | 02:47 PM
true so it makes the noise when you have the clutch pushed in? Sounds like the bearings on the ends would be my first guess
Old Apr 29, 2006 | 08:30 PM
dogma's Avatar
No, it makes the noise when the clutch pedal in out. Also what is the difference in gear ratios if any between the SI and the other models? I found a tranny out of a DX, would I see much differance if I were to switch over to that one?
Old Apr 29, 2006 | 08:51 PM
mentaldis0rder's Avatar
u dont want DX tranny.. Si trans are better... same with EX.. which is why i will be looking for EX trans with LSD if i can locate
Old Apr 29, 2006 | 09:07 PM
about 95 % of the time if its making noise when its out then its your throw out bearing
Old Apr 29, 2006 | 10:42 PM
AgentofDarkness's Avatar
Doesn't the throwout bearing engage the pressure plate when the clutch is pressed it? As far as i know, the throwout bearing turns when its engaging the pressure plate/clutch.
