Interchangeable D series trans....
Old Mar 29, 2007 | 04:09 PM
blackwagonman's Avatar
Default Interchangeable D series trans....
My question is are all of the EG (92-95) D series transmissions interchangeable? The reason I ask is because my tranny is going out on my 92 CX HB and I picked up an EX tranny for $50 dollars. I am pretty sure it should just bolt right up, but figured I should ask before I start pullin everything apart. Thanks
Old Mar 29, 2007 | 06:52 PM
finalimpact's Avatar
Default RE: Interchangeable D series trans....
bolts right up.........any 92-00 sohc d series transmission will bolt right up.
Old Mar 29, 2007 | 06:54 PM
StifflersMom's Avatar
Cat Fuсker
it should bolt up, but the gear ratios are different
Old Mar 29, 2007 | 08:48 PM
Thanks for the confirmation! Just out of curiousity ... isn't the EX's transmission gear ratio better than my current CX's. That is a good thing.... right? I shouldn't have to worry about ECU issues with swapping the tranny's on a manual.
I am thinking about going with an ACT clutch and lightweight fly wheel while I am in there. Is that worth doing? Thanks again for the help.
Old Mar 30, 2007 | 12:17 AM
any hydro sohc tranny is better than your cx. and it wouldnt hurt at all to drop a new clutch kit in while your at it. as far as the auto ecu, it can be used or converted to 5spd.
Old Mar 30, 2007 | 10:03 AM
riceburner700's Avatar
the cx tranny is great if you have a lot of horsepower lol or are trying to do top end runs. best is like an si or ex tranny
thakid
Jul 12, 2006 09:46 PM
mentaldis0rder
Apr 21, 2006 10:26 AM
turbocivic16
Apr 13, 2006 09:30 AM
DV92Camaro
Jun 23, 2005 04:42 PM
Mad7s
Jan 28, 2005 06:27 PM
