MT Swap
I'm swapping my 97 LX auto tranny to a manual tranny. Does this look like a good tranny? http://cgi.ebay.com/ebaymotors/97-Ho...spagenameZWD1V
What other parts do I need to do this swap?
EDIT: Here's another: http://cgi.ebay.com/ebaymotors/Honda...hippingPayment
holy crap. Not for that much!! Where are you from? I have a 93 EX (B000) trans with grinds but will need a new differential somewhat soon. You can have it for 50 bucks. Oh, and just so you know, you can get any transmission from a 92-2000 civic that is a SOHC engine, EXCEPT for the ZC trans.
trans info:
https://www.hondacivicforum.com/m_413787/tm.htm
You'll also need...
pedal assembly (clutch, brake, gas)
hydraulic lines
clutch, flywheel, and pressure plate
master and slave cylinders
manual trans
shift linkage, shifter, boot
Manual ECU
starter
BEST INFO:
https://www.hondacivicforum.com/m_295187/tm.htm
extra info:
http://honda-tech.com/zerothread?id=1337459
https://www.hondacivicforum.com/m_197970/tm.htm
trans info:
You'll also need...
hydraulic lines
manual trans
Manual ECU
starter
BEST INFO:
extra info:
