noob needs tranny help
Old Oct 5, 2006 | 07:51 PM
trucker's Avatar
Default noob needs tranny help
hi and thanks foryour time
i'mmore of a supra guy(3 of emin fact) and i am completely out of my element here.
my wifes ex- husband's ex-wifes son(think on that one for a sec) has a stock 90 5-speed dx
car can sit at idle, and shifter can be put in any gear slot, with clutch, and no, grinding, or any ill affect at all. the issue is, it dosent go into any gear either, just the shifter hitting the hole
no excessive play, so not bushings i believe, and shaft is moving to trans, almost nothing is there, but shift effort feels completely normal, like something inside tranny is disconnected
has anyone run into this problem before, and how major a fix it is/could be
i just want a second opinion before i pull tranny out and apart
thanx for your time
Old Oct 6, 2006 | 12:45 PM
trucker's Avatar
Default RE: noob needs tranny help
but if i needed help putting in a spoon shift **** i'd have about 20 guys chiming in bynow...
Old Oct 6, 2006 | 02:24 PM
AgentofDarkness's Avatar
Did you try and move the parts where the shifter connects to the tranny? Like the part that the shifter moves (dunno whats its called). Anyway, its on the trans. Anyway, if you move this and nothing happens then that means something inside the trans is broken so you will have to pull the trans and take it apart to get to the bottom of the issue. I think you already know this, but i've never read/heard about this on this forum but maybe some1 else has seen it.
Old Oct 9, 2006 | 01:06 AM
trucker's Avatar
thanks for responding
yes the linkage is shifting all the way to the tranny, seems to be dosconnected somewhere inside
are there any recourses avl online for blow apart pics of this? similiar to our tsrm in the supra world...
Justinhorne
Jul 29, 2014 07:19 PM
Drdslove
Jun 3, 2009 08:12 PM
LEVIII
Jan 10, 2006 02:26 AM
dystopia
Jul 15, 2005 02:16 AM
BUCKSHOT
Apr 25, 2005 03:01 PM
