performamce clutch
Old Jul 25, 2010 | 12:24 AM
pandagirl's Avatar
Question performamce clutch
I;m looking at upgrading my clutch to a stage 1 performance cltuch with an aluminum light weight fly wheel, but heres the thing i have no clue which performance brand will give me the horse power i want and is best for my car. I was hoping someone could help me, possibly tell me what performance brand is best to look at. i've seen sone on a few performance sites but i dont know the difference between the 5 or 6 star clutch plates or the solid ones. so if anyone can or wouldnt mind i really need some help please.
Old Jul 25, 2010 | 08:06 AM
You get no extra horsepower from an upgraded clutch. The clutch allows you to transfer the extra power from the modifications to your motor to the wheels.
Do not cheap out on a clutch. It takes time to install, and isnt the most fun of things to do. Having to pull everything off twice because a junk clutch was installed would suck. I have a stage 2 Competition Clutch (that is the name of the company) with an 8lb flywheel.
The "solid" ones are considered a street disc. I would go for them unless you had no other choice. The "5/6 star" clutches are a "puck" clutch. Not exactly sure which is better, but I do know that the pucked clutches make more clutch "chatter".
What kind of modifications do you have on your vehicle? If nothing extensive (read: extensive meaning more than the simple intake/header/exhaust), you do not need anything over stage 1.
Hope that helps!
Old Jul 25, 2010 | 09:46 PM
Sounds like you don't really need a new clutch.
Old Jul 27, 2010 | 08:09 AM
pandagirl's Avatar
actually i do need to replace my clutch, the stock clutch is chattering preety bad and is starting to slip so i need to replace it before it goes out while i have the money. but i was looking more for brands. a friend told me excedy but im sure theres more
VXHatchHero
Jun 13, 2010 09:42 AM
NIKE H34D
Jan 5, 2009 01:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
