Second gear problem
Old May 29, 2007 | 09:23 AM
cjain58's Avatar
Default Second gear problem
I have a 2001 Civic LX with Manual drive. Occasionally, I have trouble getting into second gear. This usually happens during the first few minutes of driving. All other gears work fine. Please advise. An estimate of the approximate costs to fix the problem would be helpful too.
Old May 29, 2007 | 10:08 AM
SovXietday's Avatar
Default RE: Second gear problem
Try changing your transmission fluid and see if that helps, use the GM sychromesh and you should be good to go.
bakrueger
Aug 28, 2011 12:03 PM
honda_dud
Jul 10, 2009 06:48 PM
that guy
Apr 14, 2007 12:45 PM
OrangeNBluCivic
Apr 27, 2006 03:40 PM
OrangeNBluCivic
Apr 22, 2006 10:37 AM
