SHORT SHIFTER
Old Apr 7, 2007 | 11:57 PM
blackmetal619's Avatar
Default RE: SHORT SHIFTER
yea i agree. If your down with the ebay ones, then get one. I just look into how much shorter the shifts get. TWM has some good shifters, and have a stage one and stage two.
Stage 1:
- 1.5" height reduction
- 40% throw reduction
Stage 2:
- 3" height reduction
- 55% throw reduction
Old Apr 8, 2007 | 08:16 AM
Height reduction is only going to hinder performance..
Old Apr 8, 2007 | 01:32 PM
civicexracer's Avatar
i havea cheapo one that i got from the local autostore. have had it on for about a year and half, gone thru a bunch of races, and no problems at all. im extremely happy with it, esp since it cost $20. i suppose it would be equivalentto any "ebay" short throw shifter(ppl, ebay isnt the company that makes the product), so i'd say go for it. i figure so long as u dont go all nuts when shifting, it'll be alright.
Old Apr 8, 2007 | 02:51 PM
Live_4it's Avatar
I think the ebay ones are fine unless you like to shift hard. I heard of people breaking them because of the kind of metals used in the ebay ones are not as strong as the name brand ones. But if you shift pretty casually chances of it breaking are minimal.
Also the ball on the shifter (which reduces throw, time between gears) is a lot smaller on the ebay ones, if you still like a little roomin betweenshifts it might be a better idea to go with one that has a smaller one.
Old Apr 14, 2007 | 08:26 PM
tha_next_Kobe's Avatar
i'm in the midst of my shorty install and i'm having trouble getting the stock shifter out...the ball seems to be stuck and i'm not too sure how to get it out...should i be pulling it up through the car or pushing it down to get it out below the car...any help asap would be great! thanks!
Old Apr 14, 2007 | 10:14 PM
StifflersMom's Avatar
Cat Fuсker
you have to unbolt the linkage buddy, don't try to force that ball up or down. Take the removable part of the linkage off and you'll be happy...
Old Apr 14, 2007 | 11:04 PM
thanks for the reply...ended up figuring it out on my own, just a matter of taking it all in! the problem i've run into though which is sorta minor, is that the base of my new short shifter seems to be rubbing the top of the exhaust pipe just before the resonator...i've tightened all the bolts and it is as high up as it can go, any advice?
Old Apr 14, 2007 | 11:09 PM
Cat Fuсker
sometimes you need longer exhaust hangers to offset the new shifter))
Old Apr 15, 2007 | 02:45 AM
importcivicus's Avatar
ORIGINAL: blackmetal619
Stage 1:
Stage 2:
I can say that I had the stage 2 and that shifter was lower than the consul pice where sat. With a shift **** it was like 2 inchs above it. But i loved it.
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
addiction2bass
Dec 25, 2007 10:46 AM
heathershonda
12
May 10, 2007 07:18 AM
ELECTRON BLUE 2000
Apr 18, 2007 11:00 AM
05CivicLX
Jun 4, 2005 12:46 PM
