tranny problem
Old Dec 18, 2010 | 09:02 PM
757honda's Avatar
Default tranny problem
a few weeks ago my speedometer stopped working before the new sensor came in my problem has esculated. now it is hard to move the gear shifter at all. even when in neutral. its a 97 civic ex coupe 5 spd. i can get it in gear and the engine will rev up and the car will barely move. is the transmission gone?
Old Dec 19, 2010 | 09:09 AM
replace you clutch
Old Dec 19, 2010 | 09:18 AM
GrantsCivic's Avatar
sounds like the clutch is slipping or almost gone compeletly
Old Dec 19, 2010 | 05:46 PM
If changing gears is also difficult with the engine off, then you may have a transmission problem. Also check whether an axle popped out of the differential.
Old Dec 19, 2010 | 07:37 PM
757honda's Avatar
the shifter is hard to move while its running or off. i know my cv axle was starting to pop before it all happen too.
Old Dec 19, 2010 | 07:39 PM
Also check the shift linkage.
sway2003
Apr 22, 2008 12:15 PM
Civic Dx 349
Nov 7, 2007 06:35 PM
davster
Sep 28, 2007 10:23 AM
pregohatch
Jul 9, 2006 09:21 AM
darknightmr2
Mar 14, 2006 06:44 PM
