trans?
Old Sep 20, 2009 | 08:12 PM
NDel's Avatar
Cool trans?
hey, i have a 97lx that i did a stock swap on when the motor locked. when i did it i decided to put a new cutch in it so i got one from autozone. it has been driving fine for months but now it bucks hard and you cant give it enough gas to stop it when taking off in frst gear only. i have to take off from 2nd and everything shifts and drives fine after that. does this sound like a cheap clutch issue or something worse from the trans? any ideas would be great. thanks
Old Sep 21, 2009 | 02:31 AM
can you explain that a little more not sure what you mean.
Old Sep 21, 2009 | 02:08 PM
NDel's Avatar
if i am stopped i cannot take off from first gear. it feels like when you first learn to drive stick, it bucks hard if you let up too early. this is what it does regardless of how much gas you give it, the whole car shakes like its gonna stall. this only happens in first gear so taking off in second is no problem and it drives fine after that.
Old Sep 21, 2009 | 03:58 PM
droopy128's Avatar
When you said it ‘buck hard’, meaning it difficult to release like it stuck in gear?? If it is, you may have a cheap clutch plate where the spring has fallen out.
Old Sep 21, 2009 | 08:26 PM
NDel's Avatar
no, not really. you can shift it in and out of first no prob and when youre driving there is no problem. the clutch pedal doesnt feel off in any way in or out of gear and the shifter goes in and out gear no problem. only when taking off from first (and it doesnt do it every time) it has the feel just like you are gonna stall, like if you didnt give it enough gas goin up a hill and the car just bucks. but its not just bad driving, i cant give it more gas or keep it going. i have to clutch it and start in second.
Old Sep 21, 2009 | 08:29 PM
does it feel like its hopping? because if the flywheel doesnt have a clean cut surface than when you take off from first you really feel it.
Old Sep 22, 2009 | 10:05 AM
NDel's Avatar
could be, i didnt resurface it when i did the clutch. i thought if that was the reason it would slip when i wind out a gear too, like if i was in second after 5k rpms. sounds possibly though, thanks
Old Sep 22, 2009 | 10:20 AM
when a flywheel doesnt have a clean cut surface then when you take of in first it jumps.
that is the sign. it wont slip in high rpms.
Old Sep 23, 2009 | 05:12 PM
NDel's Avatar
cool, i live in central nj. does anyone know any shops that will resurface a flywheel in the area??
Old Sep 23, 2009 | 06:13 PM
You can buy one at the auto parts. They arent that expensive.
yetti8
Oct 1, 2007 10:26 AM
bonzitre
Jan 21, 2007 08:51 PM
Lordnismo
Sep 26, 2006 03:07 AM
Mikey123
Sep 16, 2006 02:31 PM
jtshop
Sep 8, 2004 06:01 PM
