Trans or Clutch
Old Mar 23, 2005 | 12:56 PM
vdog's Avatar
Default Trans or Clutch
When my car is in neutral, it makes a slight grinding noise until I depress the clutch then it stops. My clutch is strong, no slipping or anything like that. I was told I need a new clutch, I have heard noise when in reverse like grinding and shuddering. But again, no slipping.
96 civic. Help!
Old Mar 23, 2005 | 04:57 PM
finalimpact's Avatar
Default RE: Trans or Clutch
does the clutch need to be almost fully depressed in order for the sound to go away?
Old Mar 23, 2005 | 10:14 PM
sacicons's Avatar
check your tranny oil level. actually, its opnly 2 quarts, just change it, it probably needs done anyway.
Old Mar 24, 2005 | 02:22 PM
vdog's Avatar
Actually once its depress a lil bit the sound leaves.
Old Mar 24, 2005 | 11:53 PM
sacicons's Avatar
throwout bearing.
Old Mar 26, 2005 | 02:08 AM
D16z6's Avatar
Also make sure that you are completely stop when you put ur car into reverse. I use to let my car roll down the drive way and put it into reverse while it still moving which made some ugly grinding noise.
Old Apr 11, 2005 | 02:32 PM
vdog's Avatar
Ok peeps, I changed the clutch, press plate, flywheel, flywheel bearing and throw out bearing, trust me, the clutch was going. Nice and smooth. Now I still here the throw out bearing until I depress the clutch. Is that normal? Also what is that rattling noise I hear in front under the car? When the car was on a hoist, I grabed pretty much everything to see if something was lose, and it was not. Help with the sound.
Old Apr 11, 2005 | 07:56 PM
sacicons's Avatar
could be your input shaft bearing, but probably not if you have to push the clutch more than an inch or two to get it to stop.
Old Apr 12, 2005 | 01:54 PM
vdog's Avatar
Got the noise to stop. My resevoir was all of a 1/4 inch from the top if it was that much.
I added maybe two caps of brake fluid, and the noise stop. I figured it would not make a difference, I guess I was wrong. Thanks for all the help.
kbeezy13
Feb 28, 2008 06:14 AM
yetti8
Oct 1, 2007 10:26 AM
snosurfa7
Apr 24, 2007 07:30 AM
bonzitre
Jan 21, 2007 08:51 PM
Lordnismo
Sep 26, 2006 03:07 AM
