Transmission better performance
[/align][/align]Item Description | Vehicle Application | Shipping & Handling | Payment Details | Return Policy | About Us
About this item
[/align]
This is a brand new genuine Exedy standard OE replacement clutch kit. This clutch kit contains all the necessary components to do your clutch replacement and is the perfect setup for any stock or lightly modified vehicle. Exedy Globalparts Corporation was founded in 1923 and its clutch manufacturing business and prominent brand name Daikin Clutch are known throughout the world for supplying quality powertrain products. Exedy supplies to all 11 vehicle manufacturers in Japan as well as many other vehicle manufacturers including including GM and Ford. Exedy is the largest clutch manufacturer in Japan and their name stands for the highest in quality and performance. [ul]This complete clutch kit includes:[*]Exedy Pressure Plate[*]Exedy Clutch Disc[*]Release Bearing[*]Pilot Bearing[*]Alignment Tool [/ul]
KHC08-EX #11
Buy from the right seller! Gripforce is the largest Exedy distributor on eBay! We gaurentee the lowest price on all genuine Exedy products on eBay. Please visit http://www.exedyusa.com/oe/dealers.asp and look for our company Speed Solution International. Note that only genuine Exedy/Daikin clutch kits (not repackaged) come with a 12 month/12,000 mile manufacturer warranty.
[/align][/align]Back to Top
Vehicle Application
[/align]1992 - 2004 Honda Civic 1.5L, 1.6L, 1.7L, all model except DOHC VTEC
1993 - 1995 Honda Del Sol 1.5L, 1.6L, all model except DOHC VTEC
Do you think it would be a wise ideafor someone on a tight budget to buythis exedy clutch, alongwitha nice flywheel to go with it forbetter performance? If they had a98 civic EXwith around 115 tq and 135 hp and aren't planning on haveing more than 130 tq and 170 hp.
Or is there a better method for a person on a tight budgetwanting better performancefor the transmission, like just resurfaceing the flywheel keeping same clutch, or getting better clutch keep the same flywheel.
If it's really only worth itto install a stage 1 or stage 2 clutch kit to make a real difference, along with flywheel. I would like to know cause I would just save up for that. (Even though it will be awhile)
Big Thanks if I get a reply!
ORIGINAL: SovXietday
You're not making enough power to warrant anything other than the need of a stock clutch. Save yourself the money, clutches are a bitch!
but if you go with a lightweight flywheel, you will notice an improvment in how quickly your motor can rev up ..(less rotational mass)
Ashton117
Dec 8, 2004 02:13 PM
