Transmission Flush?
Old Aug 30, 2005 | 01:24 PM
REGNARTS_'s Avatar
Default Transmission Flush?
I've been looking forever on how to change the transmission fluid in a 95 ex manual trans. I've asked around but seems like no one really changes their transmission fluid. I want to change mine, any DIY's on how to change a manual transmission fluid?
Thanks.
Old Aug 30, 2005 | 02:17 PM
neon3kgt's Avatar
Default RE: Transmission Flush?
there should be a drain plug on the bottom... and a fill plug mabie half way up. when it runs out of the fill hole, its full. iv never done it on a honda, but thats the only way i have seen it.
Old Aug 30, 2005 | 10:06 PM
sacicons's Avatar
theres a plug on the passengers side of the tranny, its not a bolt, but you stick a 3/8 ratchet straight into it to loosen it (no socket). then once its drained, close it back up and pour 2 quarts of 10w-40 in through the 17mm bolt-hole above that, near the top of the rear of the trans.
Old Aug 31, 2005 | 01:45 AM
REGNARTS_'s Avatar
Guys, pictures would really help. I'm not big on cars, I just don't want to pay $80 so I thought I come here to ask for help. I sort of understand what you mean sacicons but I don't think I will be able to locate what you just said........
Old Feb 29, 2008 | 08:41 AM
ACE_92's Avatar
Yes if someone could show a picture of these to holes that would be great.
Also what fluid do I use, In the manual I believe you can use regular 10w30 oil, can you also use synthetic ?
Old Feb 29, 2008 | 05:39 PM
ACE_92's Avatar
Hey, thanks for thetips guys. I just finished it today. Minus the trip to the dealer for the syncro mesh ($13 a quart) it was a very quick job. The bolt that is the filler hole is hard to miss its a 17mm bolt that is below and alittle to the right of the fuel filter. I put in 2 quarts and a few seconds later it started pouring out. Tightened everything up and took her for a spin. It actually made the tranny feel smoother. Not a bad job. Best part no filter to replace.
sfazngiants
Feb 12, 2008 08:22 AM
txedomask433
Aug 3, 2007 06:09 PM
amsmk
Jan 22, 2006 01:57 AM
4D4GCIVIC
Jan 8, 2006 03:25 PM
Super Mario
Mar 7, 2005 02:09 AM
