Transmission Problems?
Old Oct 10, 2008 | 08:44 PM
nitika's Avatar
Default Transmission Problems?
I have a 2003 Honda Civic with 80,400 miles on it. I just had to replace the transmission. This weekend I was driving and my check engine light went on, the car wouldn't shift into third gear, it hesitated when I put it in reverse and it smelled like buring oil. Did the mechanics forget to attach something? Will I need to get another transmission, or is something else wrong? Thanks.
Old Oct 10, 2008 | 11:41 PM
Another question would be: Did the mechanics forget to put in something? (i.e. transmission fluid)
Call them and tell them what's up, and make sure they don't charge you to fix it if it's their fault.
Old Oct 11, 2008 | 01:31 AM
knoxville's Avatar
Is it an automatic? If so it might be a torque converter issue. Was the torque converter replaced along with the transmission. I would look into that.
_____________
gas saving tips
Old Oct 11, 2008 | 02:00 AM
read his post again
it's a manual transmission
Old Oct 11, 2008 | 06:03 AM
I agree with Trust -- Start by calling the mechanic and checking whether the transmission is low on fluid. As there are no CEL codes for a manual transmission, the OP actually may have an automatic transmission. To retrieve the CEL code(s) from the ECU, you would need to take the car to AutoZone, though this may not be feasible at this point.
Old Oct 11, 2008 | 10:19 AM
yea but he said he couldn't shift into third gear. If he couldn't shift into 3rd, he probably would also say he can't shift into 2nd or 1st (or whatever the 01-05 Auto Shifter calls it)
kinda odd because yea there's no CEL for manual transmission
Old Oct 11, 2008 | 10:29 AM
Yeah, I guess we need to wait for clarification.
karney
Jul 31, 2006 04:23 PM
futurecoach
Jul 28, 2006 09:27 PM
drewbhot
Feb 20, 2006 04:13 PM
cvccitizen
Jan 16, 2006 03:07 AM
seeliassen
Aug 8, 2005 03:46 PM
