Would this trani fit??
Old Jun 1, 2009 | 06:13 AM
madjoker14's Avatar
Default Would this trani fit??
just a quick question guys, i have a stock automatic 99 civic 2 door, with a d16y8 engine,(trani idk) but i want to swap out the motor n trani but first i have to change alot of things, for example, i have to install the pedals, lines etc,
so i was thinking b4 i get the motor y not just get the trani n do that job, so i was wondering could a b18 trani fit with my current d16y8 engine that currently installed, would i need harnes work ? anything like that?
thanks for any info
Old Jun 1, 2009 | 01:22 PM
no, D-series transmissions only.
Old Jun 1, 2009 | 04:21 PM
plethoric33's Avatar
Trannys are series specific in all cases, except the h2b.
Old Jun 1, 2009 | 04:49 PM
yep. D only.
Old Jun 16, 2009 | 08:30 AM
primevil1's Avatar
You could buy and install the d-series manual transmission, then when you swap engine and tranny you already have the pedals, shift linkage and clutch pedal/system installed. That could make the final swap easier, but then you would have to buy an extra transmission.
Old Jun 16, 2009 | 08:38 AM
chasemclemore's Avatar
not trying to hijack the thread but I think you guys answered the original question.... b series will NOT work on D... so my question is will ALL D Transmissions work on ALL D Motors like a y8 tranny would be the same as Z6 tranny im just curious and thats just an example
Old Jun 16, 2009 | 10:48 AM
yep. the Y8 EX tranny will bolt right up to the Z6. only difference is the better internal parts are tuffer than the Z6 tranny. so if you have a Z6 its a good upgrade to go to Y8 tranny. but if you have a Y8 then i wouldnt suggest the Z6 tranny if your abusive slammen the gears. but if you drive normal than the Z6 is still a upgrade from the Y7 just not as strong internally as the Y7 Y8 ones, should get you by if your in need of a good tranny tho
Old Jun 16, 2009 | 04:44 PM
When ever you get to the point of swapping, try to get a GSR trans or a B16 trans. They are shorter geared than the LS (b18ba and b18b) trans. However, if you plan on going the boost route, find a Hydro LS, longer gears are always a plus with boost.
madjoker14
May 30, 2009 04:01 PM
madjoker14
Nov 3, 2008 09:51 AM
madjoker14
Mar 14, 2007 05:12 PM
startiger
Feb 26, 2007 04:29 PM
StreetGlow_ciVic
Aug 8, 2006 10:31 PM
