I GOT A PROBLEM SHIFTING.....
Old 05-11-2007, 01:35 PM
jvcivic's Avatar
Default RE: I GOT A PROBLEM SHIFTING.....
ya,thats excactly what is wrong with mine..feels like a extra gear.and its fine after it outta the gear.ill try that.thanks kev99sl.
Old 05-11-2007, 01:47 PM
cpl rampage's Avatar
im not to familliar with autos, but maby it the brake pedle interlock, the thing that makes u press the brake down to take it out of park. im not too sure how this works on an auto weather or not it is in the shifter or the tranny, ill look in my manual and see if ai cant fina somethign
edit:
yah, the shift lock solenoid is atached to the shifter inside the car, you may want to do wat adiction to bass said and clean off all that stuff, and then check to make sure the solenoid actually moves when u press the pedal, and that it moves enough, in the manual it tells u to kinda hotwire the solenoid to measure if it moves out of the way enough
Old 05-11-2007, 01:52 PM
jvcivic's Avatar
i tried that,the interlock system seems fine.its works.
Old 05-11-2007, 02:13 PM
ic892003's Avatar
when was the tranny fluid last chnanged??
Old 05-11-2007, 03:55 PM
jvcivic's Avatar
im at 212000 km and i changed it not too long ago.i think around 190000.i dont have the records near me but i know i changed it around then..
u think it might have anything to do wit the transmisson itself???
Old 05-11-2007, 04:08 PM
well id doubt it actualy inside the tranny... but it could be that lock solonoid on the shifter... maybe its geting old/worn and its not pulling the shaft outta the way which locks the shifter from shifting gears unless the brake pedal is pressed...
but again just an idea....
could try inspecting it with the cover off press on the brake and play with the shifter back and forth and see if it looks like anything is causing a drag or not releasing all the way. which sounds like it might be to me...... might have to remove the shifter unit from the floor to take a beter look at it when shifting thru it... or have a friend move the gears while ya play with the brake pedal same time....
Old 05-15-2007, 11:49 AM
Mine is all-clear. Everything on the inside of the car is working OK, including the brake/shifter release mechanism. To test the shifter, take the console off and put the car in neutral, then disconnect the shift cable from the shifter. Try shifting and see if it operates smoothly -- mine does. I took the cable cover off at the transmission end, and it is pretty rusty. I sprayed it down with WD-40, and that seemed to help it some. My conclusion then is that corrosion on the transmission end of the cable is the culprit. I'm replacing the cable and and hardware this weekend. Note that the cable is nicely covered by a flange held on by two bolts, but mine was rusted anyway. Hope this helps.
Old 10-28-2008, 07:33 PM
Madtytecivic's Avatar
Did this fix the problem? ^
Old 10-28-2008, 10:21 PM
Unhappy
he's only got 2 posts, inactive since 2007
unfortunately i don't think he's coming back to answer you
Old 10-29-2008, 07:49 AM
yea well ithought i would try and see if anyone else would chime in on this again. Im having the same problem
dsmoore
03-13-2018 08:25 AM
civic28
12
07-12-2009 08:03 PM
chikna
07-18-2008 10:51 AM
jvcivic
05-11-2007 07:54 PM
ic892003
07-21-2006 10:54 PM
Quick Reply: I GOT A PROBLEM SHIFTING.....
