numbers after engine code
Old 08-08-2006, 12:33 PM
Hot94vtec's Avatar
Default numbers after engine code
Hey do any of you guys know what the number after the engine code mean? For example i have a B16A, what is the difference between the B16A, B16A2, and the B16A3? Just was wondering why the numbers are there and what they mean. Thank you
Old 08-08-2006, 07:35 PM
Fiirkan's Avatar
Default RE: numbers after engine code
IIRC they are just to distinguish between the different engines, for example there are a number of B16 engine, all of them being 1.6L but the varisation differ in power and torque, for example, the B16A2 has 160hp and 111ft-lbs/tq, but the B16B has 185hp and 118ft-lbs/tq, but then there is also differing generations of the engines too for example, a B16A out of a JDM 89-91 Civic SiR has 160hp and 111 ft-lbs/tq, but the B16A out of a European 92-95 Civic has 170hp and 116ft-lbs/tq, so sometimes it can be confusing, but most of the time, there is only one engine, for a certain power band,
Old 08-08-2006, 08:02 PM
Hot94vtec's Avatar
Hey thanks for the reply, you helped alot, but i have a B16A, and i want to know if it is japanese or european and what car it came out of. Is there and way you can tell me how to find that out? It would be So helpful. Thank you
Old 08-08-2006, 08:19 PM
Fiirkan's Avatar
ahh... ummmm... well that is the tough part, unles you can get the serial number on the engine and run that through some sort of system then i honestly don't know of a way to tell ya what is was from, but it was out of one of the two i mentioned above,
AllForSRT
05-23-2006 11:20 AM
WhatsAClutch?
03-29-2006 09:11 PM
jim9418
12-16-2005 02:01 PM
maddawg
08-22-2005 10:14 PM
Quick Reply: numbers after engine code
