passing emissions tests
i heard from a guy that works at meineke that if your running catless and you go in for an emissions test you should put a couple cups of rubbing alcohol in your gas tank and run with it for a few miles that you will be able to pass the test just fine....is this really true? would rubbing alcohol really work like that? also, would there be a chance of hurting your engine if you used it?
RE: passing emissions tests
Rubbing alcohol huh?
Last time I checked, rubbing alcohol was about 50% isoproponol and the balance was water.
Go ahead and check the label under "Inactive ingrediant"
So, you really want to dump water in your gas tank?
danomatic93
05-21-2008 08:09 PM
ryank327
09-26-2007 12:14 PM
