CEL on 2 codes
CEL on 2 codes
1999 Civic EX
1st code P0705
Transmission Range Sensor Circuit Malfunction(2 pos)
2nd code P1337
Crankshaft Position Sensor 2 no signal
What exactly do these mean and from all outward appearances the car is running fine...Is it okay to continue driving it?
1st code P0705
2nd code P1337
73 ppl read but no one has anything to say? I really would like to know as i need this car as a daily driver and at the moment dont have the funds to get it fixed...so is it safe to drive or not?
The crank sensor on distributor OBDII models is just to detect if the timing belt has skipped. All the critical timing signals come from other sensors in the distributor. So you can ignore it. It's common for the sensor wires to get caught in the pulley or belt if they aren't installed properly.
The other one apparently has something to do with the automatic transmission, which I know little about.
With an EX, if the CEL is on for any reason, the engine will have a lower rev limiter and the VTEC will never engage. This really isn't an issue in daily driving though.
