Does the engine need to run to get any useful info from an OBD?
Old 03-16-2016, 12:03 PM
estes53's Avatar
Question Does the engine need to run to get any useful info from an OBD?
Does the engine need to be running in order to get any useful information from an OBD?
I have an engine that will not start and am willing to buy a cheap OBD if there is a chance that it will help me.
Alan
Old 03-18-2016, 10:55 PM
Ska-T's Avatar
The engine does not have to run for a scanner to pull Diagnostic Trouble Codes and Inspection/Maintenance Monitors. Turn the ignition key to the ON position.
If you don't have a current check engine light then there may not be a code to display (although there could be a pending code).
Have you read a basic article on troubleshooting a car that won't start?
Troubleshooting a Car That Won't Start - For Dummies
(ignore the website name)
Old 03-19-2016, 03:55 AM
estes53's Avatar
Thanx, that's what I was hoping.
BcBaudoux
03-20-2010 12:57 PM
JosephAdam22
07-24-2008 05:38 AM
SoCaL.rider
37
11-26-2007 10:28 AM
WHISP63
10-24-2006 11:04 AM
stick only
11-17-2004 07:23 PM
Quick Reply: Does the engine need to run to get any useful info from an OBD?
