Drove With Emergency Brake On, Regular Breaks Failed
Old 08-17-2015, 12:32 PM
FM Mood's Avatar
Default Drove With Emergency Brake On, Regular Breaks Failed
What's up guys. I'll try to keep it short and sweet.
Friend borrowed car left E brake on, I dumbly didn't realize and drove it about 10 miles with it on. For some reason my car's emergency brake indicator light doesn't turn on. Oh well.
As I was driving it I felt it behaving strangely.. most notably that when I would apply the brake, most of the times it just went down to the floor with no resistance and didn't brake the car.
At first I thought I was hitting the acceleration by accident because I had been driving a truck all day and thought maybe I had gotten used to the trucks pedals..
But then I realized, no I was hitting the brake and it wasn't applying.. and I had been smelling a subtle burning rubber smell... Oh **** ****.
Few seconds later realized the E brake was on, switched it off.. I forget if I was moving or stopped when I turn it off... Let's just assume I was moving when I did because that would probably be the most damaging.
Anyway.. Even after I turned it off.. the brakes still didn't work properly.. It was scary to say the least. Pumped the brakes and they started to work a slightly better.
Made it home in one piece. In the driveway I pumped them a little more and tested them out and now they seem to work again. But I'm nervous that something still could be very wrong.
I've driven it around to the store, couple miles.. seems to have no problems. But I am still concerned. Do you think this warrants taking it into a mechanic?
And what is the most likely damage that I caused?
Old 08-19-2015, 04:15 PM
itburnswhenIP's Avatar
the brakes overheated and the fluid started to boil i would flush the brake fluid system. only use honda brand fluid.
sparkhard
01-15-2008 04:30 PM
ugh3012
12-30-2007 06:02 PM
rit14623
01-10-2007 10:48 AM
bigRalph
08-26-2006 08:09 AM
00civicEX
07-24-2006 08:07 AM
Quick Reply: Drove With Emergency Brake On, Regular Breaks Failed
