Engine Swap Done, Engine runs SOMETIMES...HELP!
Old 11-18-2007, 09:40 AM
skibum853's Avatar
Default Engine Swap Done, Engine runs SOMETIMES...HELP!
ok, finally finished the engine swap. b16b into 98 civic cx. a little background. engine has: skunk2 intake manifold, tb, valves springs retainers. msd pro billit dist, wires, blaster coil and ignition controler among many other things. my problems is....some times it just wont start. it will crank and crank and crank but wont start. now if i get out and spray a little starting fluid in the line going from the valve cover to intake, put the hose back on, then get in and try to start it, it will fire right up. so im guessing its a inital fuel delivery problem but i just have no idea where to start to try to fix this. its just confusing because sometime it will start right up. oh...and i do have a fuel pressure guage that reads right at 44 psi. thanks for the help guys
puckman1325
01-19-2012 01:28 PM
cosmond
12-14-2009 04:43 AM
charliccs
15
06-29-2009 08:56 AM
addiction2bass
02-13-2008 07:59 PM
natas638
02-01-2007 12:13 PM
Quick Reply: Engine Swap Done, Engine runs SOMETIMES...HELP!
