Tires Rubbing
Old Apr 6, 2009 | 05:58 PM
Evanjl's Avatar
alright ill have to look around to see if i can find a set of stiff springs. My car will ride like a brick but it wont rub and will handle better.
Old Apr 6, 2009 | 06:08 PM
Originally Posted by inthezoneac
what car is that with a 3" drop. My almost 2" drop will rub if I lowered it anymore. 2054017's with 40 offset. I could lower the back a bunch and not have it rub, but the front would need me to take out the fender liner and I would never do that.
This car, douchebag
It's called +45mm offset wheels, no fender liners, rolled front fenders, and 3 degrees of negative camber. If you're like me, you already wash the wheel wells when you wash the car, so who cares if you get a little dirt in the wheel wells? Now go be annoying somewhere else.
To the OP, I'd recommend coilovers. They usually have higher spring rates than normal lowering springs, not to mention you can set your ride height exactly where you want it. Just make sure you get good struts or you'll blow them and bounce all over in no time. My suggestion (if you have the money) is Ground Control coilovers and KONI yellow struts. I have yet to hear a bad comment on that combo.
And remember, it ain't a drop until it looks like this:
But speaking of negative camber.... as long as your toe is set back to factory specifications, you won't go through tires any faster unless you're running an incredibly soft compound. I ran 3* of negative camber on my civic... no premature tire wear whatsoever:
Old Apr 7, 2009 | 01:32 AM
  #23
your car doesnt have to ride like a brick!
that was mine and wasnt to bad at all!
trust me you dont want the car to ride like a brick..... it will beat the hell out of you and youll be whining about it fast! youd be better off replacing the parts with stock parts! at least then the drive to the grocery store wont beat you to death!
Old Apr 7, 2009 | 01:53 AM
  #24
yeah the whole brick thing sucks my car is lowered and i have no clue wat kinda springs or wat is on it [came with car] but dam especially now with 16's i feel every bump and hard with no sidewall to take it.... i cant stand i need to get em off whenever i get the money
i am pretty sure it is a no name brand from ebay like everything else on the car lol ebay intake, ebay exhaust, ebay strut bar, and prob springs too..
Old Apr 7, 2009 | 09:43 AM
  #25
plethoric33's Avatar
If you dont go stock, Id go with Addiction's setup. The Tein S-Techs are pretty soft, but not as soft as stock. And the Tokico HP's match pretty well with them. So its not a very expensive setup.
Dipsetcivic117
14
Jul 14, 2008 11:37 PM
inthezone
Mar 12, 2008 08:39 AM
trustdestruction
Dec 21, 2007 02:26 PM
TSR96civic
15
Aug 19, 2007 07:58 PM
95redcivic
Feb 27, 2006 11:22 AM
