EK Swaps 1996-2000 Civics
b16a2 swap
Old Nov 3, 2004 | 10:17 AM
Blackhatch124's Avatar
Default b16a2 swap
hey i need some help...im doing a b16a2 swap into a 96 hatch...anyone know a website that can give me some pointers?or does anyone have any trick to make it go a little more smooth?...thanks
Old Nov 3, 2004 | 05:40 PM
Default RE: b16a2 swap
the wiring is a pain in the butt. check over the whole motor first and make sure everything is hooked up. when i did my b16, i didnt hook up the one wire temp sensor under the dizzy, and the temp gauge would peg all the way hot. i couldnt find what it was for a week. get new hoses and change the timing belt and water pump, along with the clutch and maybe the flywheel. it takes 20-30 minutes to change the timing belt and water pump when its out of the car, and 3-4 hours when its in the car. i got the belt, pump, and tensioner pulley for like 110 shipped on ebay when i did my GSR. as for the actual swap, get a non-tapered punch of the right size to get the bitch pin (aka spring pin) out of the shift linkage, then hit it with some force, no tapping that sucker out. if you have any other questions, just ask. oh yeah, i know where to find a good site with the wiring info, but i dont remember the site. ill find it and post it soon.
Old Nov 3, 2004 | 05:54 PM
Here ya go.
Old Nov 3, 2004 | 11:30 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Nov 5, 2004 | 09:35 AM
yea man thanks for the advice, as far as the wiring it isnt cut in half and the motor is still in the car. Im taking it out of a civic and putting it in my civic so that will make wiring a little easier and the water pump has already been replaced as well as the clutch but not the timing belt and flywheel. but thanks for all the help ill hit you up when i finish
Old Nov 5, 2004 | 09:56 AM
2000Si's Avatar
I moved this so you'd have the honor of having the first ever post in our swap forums.
Captain_Sl0w
Oct 4, 2008 03:05 AM
civic_driver_389
EK Swaps
13
Oct 24, 2007 05:55 AM
joepops
Oct 3, 2005 12:44 AM
wwsivicww
13
May 25, 2005 01:33 PM
97b16swapcoup
Jan 16, 2005 05:13 PM
