1995 Civic aftermarket Tach install
Old Feb 5, 2006 | 12:43 PM
caper10's Avatar
Default 1995 Civic aftermarket Tach install
I am going to install an aftermarket tach in my 95 Civic CX Hatch. I need to find out where to connect the tach wire. Thanks for any help.
Mike
Old Feb 9, 2006 | 01:09 AM
Sphinx_1's Avatar
Default RE: 1995 Civic aftermarket Tach install
I have a 97 Civic, but I believe they are still the same. Where your wiring harness goes through your firewall on drivers side there is a Blue wire with a silver stripe. This wire is connected to a rubber boot that is clipped to a metal bracket right above the harness. Connect your tach wire to that wire. On mine the wire goes into the rubber boot and the spot next to it is plugged off. Here are some pictures to show what im talking about. The green wire is my tach wire.
http://imagehost.bizhat.com/show.php?id=148047
http://imagehost.bizhat.com/show.php?id=148038
http://imagehost.bizhat.com/show.php?id=148056
Sorry these pictures are huge.
Old Jul 12, 2006 | 11:58 AM
KC4's Avatar
KC4
You don't actually have to go through the firewall. If you take off your gauges there are wire clips connecting to it. Two smaller ones on each side, and two big ones--one dead center, one a little to the left. On my Honda Civic DX, the tach wire is blue with silver rings and it is on the big clip a little to the left.
WARNING: Some places on the net say that use the blue wire with silver rings on the smaller clip on the left. THAT IS WRONG! That wire goes to the airbag (SRS) light, and can be a pain if you cut it.
EightyNineDX
Aug 14, 2007 12:53 PM
ventura74
Apr 7, 2007 10:55 PM
sccatadriver
Aug 26, 2006 01:46 PM
KC4
Jul 12, 2006 11:59 AM
dalifts
Dec 16, 2004 10:34 PM
