Aftermarket Tach for 98 DX question
Old Jul 9, 2006 | 12:08 AM
KC4's Avatar
KC4
Default Aftermarket Tach for 98 DX question
I just bought an aftermarket tach for my 1998 Honda Civic DX. I tried to install if following instructions on here, but I seem to be getting contradictory information. The yellow, red, and black wires are all connected; but I need to find the wire to connect to the green wire on the tach.
In another thread someone said to connect it to the blue wire with grey lines around it near the temp gauge. That didnt work. I've also read here that you can use the blue tach wire on the otherside of the firewall. I would like to avoid drilling through the firewall if at all possible.
I've read that that one can swap the whole DX gauge cluster for an EX gauge cluster and the tach would work in the new cluster. That would suggest to me that there IS already a wire in the dash for the tach.
Could anyone shine any light on this for me?
Old Jul 9, 2006 | 02:03 AM
BlackDX's Avatar
Default RE: Aftermarket Tach for 98 DX question
There is a large grommet that sits in the upper left corner of the fire wall that's directly next to where the OE tach terminal is, a simple slice in the rubber grommet and feed the wire thru and you're good to go. Most car audio shops use grommets like this to run thier cables thru and I can say for sure you'll be okay to run the wire thru that grommet.
Old Jul 9, 2006 | 06:29 PM
dfdon's Avatar
yup use that hole dont worry about drilling
Old Jul 9, 2006 | 06:43 PM
mill$civic's Avatar
dammit, i posted a pic on here for someone before..let me see if i can dig it up
Old Jul 9, 2006 | 06:45 PM
mill$civic's Avatar
see..all you have to do is search, it was the first thing that poped up
this thread should clear up your confustion, i explane it all with PICS!!
https://www.hondacivicforum.com/m_87721/tm.htm
Old Jul 10, 2006 | 12:49 AM
BlackDX's Avatar
ORIGINAL: mill$civic
And that's why this site loves you
Old Jul 10, 2006 | 11:24 AM
mill$civic's Avatar
awwww haha i dont no about that^, but i no if i have a problem i usually find alot of stuff on the net that helps me out that people spend time posting, so mide as well do my part and post if i no a solution and try and help someone else out
Old Jul 12, 2006 | 11:59 AM
KC4's Avatar
KC4
Thanks for your replies but I ended up managing to do it without going through the firewall. You don't actually have to go through the firewall. If you take off your gauges there are wire clips connecting to it. Two smaller ones on each side, and two big ones--one dead center, one a little to the left. On my Honda Civic DX, the tach wire is blue with silver rings and it is on the big clip a little to the left.
WARNING: Some places on the net say that use the blue wire with silver rings on the smaller clip on the left. THAT IS WRONG! That wire goes to the airbag (SRS) light, and can be a pain if you cut it.
EightyNineDX
Aug 14, 2007 12:53 PM
ventura74
Apr 7, 2007 10:55 PM
sccatadriver
Aug 26, 2006 01:46 PM
caper10
Jul 12, 2006 11:58 AM
dalifts
Dec 16, 2004 10:34 PM
