Clutch install?
Old Jun 19, 2006 | 12:47 AM
GotRice?99ex's Avatar
Default Clutch install?
How hard is it to install a clutch? I really want to do it myself so i get the expierence but i also need to know the correct steps and tools needed to do it!!! anyone know and step by step guides pref. with pictures?>
Old Jun 19, 2006 | 09:11 PM
AgentofDarkness's Avatar
Default RE: Clutch install?
Get a haynes/chilton manual from your local parts store. You could also get a factory service manual from the dealer. There should be instructions on how to change the clutch in there.
Old Jun 19, 2006 | 11:48 PM
riceburner700's Avatar
is the clutch manuel or automatic? That makes a big difference on the easyness of the job
Old Jul 18, 2006 | 11:00 PM
kbeers's Avatar
You definitely need a Chilton's Repair Manual. Don't do any work on your Civic w/o one. If you have the manual transmission, you will have to drop your tranny out. You do not need to pull your whole motor and tranny out; you can unbolt the tranny and do it that way. Swapping a clutch out is one of the easiest jobs there is. the only problem w/ it is yoiu have to take ur tranny out. Make sure you drain your tranny fluid. When you get to your clutch, make sure to have a hold on it as you undo your last bolt. It will fall right out. I would suggest putting an alignment tool in.
Old Jul 19, 2006 | 03:56 AM
kbeers's Avatar
In my previous entry, I wrote a lot, however, didn't tell you a damn thing (so it seems). I will give you better info and pictures to go along w/ it. I will have that for you tomorrow.
taylorisafop
Mar 8, 2009 02:53 PM
stlhondas
Jan 31, 2008 05:19 PM
snosurfa7
Apr 28, 2007 12:39 PM
campbuds
North East
Apr 27, 2006 07:59 AM
mjt84
May 25, 2005 03:19 PM
