new clutch install
Old May 21, 2005 | 09:27 PM
mjt84's Avatar
Default new clutch install
I think its about time to change my clutch in my 99 civic LX has any one done one of these before? How hard is it? do you need any special tools? any info would help
thanks[8D]
Old May 21, 2005 | 11:01 PM
sacicons's Avatar
Default RE: new clutch install
if you can do most of your own work youll be fine. its a lot of stuff, but just take your time and do it right. get a Haynes manual and follow it. you will need a torque wrench, and you should take the flywheel off to get it it resurfaced. you have to take it off anyways to replace the pilot bearing, and it will start having problems down the road if you dont get it resurfaced.
Old May 25, 2005 | 03:19 PM
dmsteele92831's Avatar
Taking off the ball joints is the hardest part, I started to do mine but didn't have the necessary tools and didn't want to screw anything up. Then a buddy of mine hooked me up with a mechanic friend of his that replaced my clutch and flywheel for $250.00!! Normally this would cost you $500-$700 in labor alone. (I supplied him the clutch and flywheel) He's in the LA area if anyone needs there's replaced, I'm sure I could hook you up with him. For $250.00 you can't go wrong, and if you just want stock replacements you can buy through him and he'll warantee it.
taylorisafop
Mar 8, 2009 02:53 PM
stlhondas
Jan 31, 2008 05:19 PM
snosurfa7
Apr 28, 2007 12:39 PM
GotRice?99ex
Jul 19, 2006 03:56 AM
campbuds
North East
Apr 27, 2006 07:59 AM
