supercharger or turbo
Old Jan 15, 2005 | 06:54 PM
hondabboy's Avatar
Default supercharger or turbo
hey you guys already know that im going turbo on my d16y8 motor but people told me that i can get a supercharger and spend less and get the same performance. tell me what you think thanks
Old Jan 15, 2005 | 07:28 PM
Kappa22's Avatar
Default RE: supercharger or turbo
Well unfortunately, whoever told you that was wrong.
Old Jan 15, 2005 | 07:35 PM
Kappa22's Avatar
It seems that there are always certain things people overlook when they suggest a supercharger. Most of the time, they argue that a S/C will give you more low end torque. This may be true, but it isn't a good thing. I think this is the 3rd or 4th time I've posted something like this, and I think sacicons has posted numerous times on it too: A buttload of low-end torque won't do you any favors in an F/F car. Then, assuming you can get it off the line in a timely fashion, you don't get enough higer end boost to give you a real advantage. You may be able to spend less for a S/C, but you get what you pay for. There's a reason turbos cost more...
Old Jan 15, 2005 | 10:08 PM
XCM828's Avatar
Actually from my experiences, turbos cost quite a bit less then superchargers. I've seen a supercharger that dyno tested only 272 hp on a civic that cost the same as a turbo kit thats meant to handle up to 500 hp. And theres also the torque issue, as Kappa mentioned.
Old Jan 15, 2005 | 10:28 PM
Kappa22's Avatar
Yea, I actually think you're right. The only superchargers that are "cheap" per se are also pretty sad little pieces of equipment...
Old Jan 16, 2005 | 04:44 PM
hondabboy's Avatar
thought so cause i've seen people with s/c run faster then all motor cars but and keep up with cars that are turbo. but people say if you get a good price on a s/c and if you dont mind a lil power then thats ok but i think what im looking for is turbo thanks guys.
Dan
15
May 4, 2005 06:52 PM
blackeyes
Feb 12, 2005 11:05 PM
hondabboy
19
Feb 7, 2005 02:57 PM
hondafreek
38
Jan 26, 2005 03:01 PM
Jippo99
Jan 7, 2005 06:49 PM
