speakers not working please help
Old Jul 28, 2006 | 06:45 PM
Exman90's Avatar
Default speakers not working please help
my driver side front speakers are not working and i was wondering what could make that happen and how to fix it
Old Jul 28, 2006 | 08:45 PM
Default RE: speakers not working please help
IF YOUR RADIO IS STOCK....
most likely if you havent done anything on the door panel id say the speaker is blown....
just replace it with a cheapie if ya just want music....
most likely the speaker is just blown.... easiest way to tell is pull off the speaker cover and pull the speaker and look at it... if the foam stuff all looks good then move the cone alittle... if its scratchy then the voice coil is fried.... and check the tensil wires... if thiers a black spot the tensils have broken... and for a quick fix just dab some solder on the tensils on THAT SPOT ONLY!!!! if ya add to much it will stiffen the tensil wire and it wont move with the speaker and will quickly break again and this time not repairable.....
IF YOUR RADIOS AFTERMARKET....
first thing id check is pull the radio and be sure the speaker wires are still conected.... maybe the crimp conection or your twist connection has came loose...
if not then check everything above...
baddriver86
Oct 29, 2023 01:42 PM
fbbyrd
Aug 12, 2008 05:16 PM
chrisroug
Oct 2, 2006 11:36 AM
thedougler
Jul 3, 2006 06:01 PM
Exman90
Jun 20, 2006 11:45 AM
