2nd gear shift problem
Old Nov 24, 2006 | 06:11 PM
ic892003's Avatar
Default 2nd gear shift problem
i have recently noticed iit has become harder to shift into 2nd gear.. i have 2 use more force, what can cause this, someone told me i should get a transmissiion flush, but not sure any advice would be helpful
Old Nov 25, 2006 | 03:20 PM
ic892003's Avatar
Default RE: 2nd gear shift problem
nobody have an answer??? ok basically it is harder to move the stick into 2nd gear when going from 1st. i dunno what it could be shifter bushings maybe'??
Old Nov 25, 2006 | 03:32 PM
GetItBoy's Avatar
Member
i have the same problem! especially when im tryin to shift to second from a high rpm. i dont think to much of it tho. sorry i couldnt help, but maybe someone will help us both!
Old Nov 25, 2006 | 04:12 PM
ic892003's Avatar
how long have u felt this change in ur shifting?
Old Nov 25, 2006 | 04:15 PM
Misha's Avatar
If this would have been third, I would say syncro sleeve without any doubt - this is a known honda problem. Your case is most probably syncro sleeve, too. Might be a shifter linkage, though. If this is your tranny, filling it with somewhat heavier oil may help temporarily, but ultimately you have to rebuild it to fix this.
Old Nov 25, 2006 | 04:41 PM
ic892003's Avatar
when i shift into 3rd it is a litttle difficult as well, so what does this mean?? and how much does the synchro sleve cost to replace??
Old Nov 25, 2006 | 04:55 PM
Misha's Avatar
IDK, I did it myself. Sleeve itself costs a few bucks, but the job is to remove the tranny, completely disassemble it, assemble and install....
Old Nov 25, 2006 | 05:05 PM
ic892003's Avatar
ok thanks for the help i guess next time i see my mechanic ill get it checked out
Old Nov 25, 2006 | 07:58 PM
riceburner700's Avatar
try changing your tranny oil and that should help out a lot. use either gm syncromesh or genuine honda mtf or if you cant afford either use some high quality 10w30
josephemorgan91
Sep 30, 2014 09:00 PM
Juans_MX3
Apr 9, 2010 05:37 AM
Bryce132
Apr 12, 2008 08:33 AM
dk101ex
Jul 5, 2007 02:21 PM
mill$civic
Feb 12, 2006 09:56 AM
