Mid West IL, IN, IA, MI, MN, MO, OH, WI
1994 cooling fan
Old Mar 3, 2007 | 01:25 PM
Dblmn's Avatar
Default 1994 cooling fan
yesterday I replaced the radiator ( it was so clogged that it exploded the top part of the radiator by the top hose) on my ex-wifes 1994 civic. She doesn't have an owner;s manual. The fan is not comming on. When should the cooling fan turn on? How can I tell if the fan works or is just woreout. Car has tons of miles.
Also does anyone have .pdf of the repair and owners manual?
Any help would be appricated.
Old Mar 4, 2007 | 02:23 PM
AgentofDarkness's Avatar
Default RE: 1994 cooling fan
Wire the fan to the battery. Run a wire from the pos terminal of the battery to the post hole of the connector. Same for the negative. You can also disconnect the battery and check the resistance of the fan (prolly easier). If there is an infinate resistance, the coil inside the fan is burned out and it will not work.
lillyrat
May 22, 2007 09:31 PM
Dblmn
Mar 4, 2007 01:54 AM
mitchamus
Jan 2, 2007 02:28 PM
DashRendar77us
May 25, 2006 07:29 PM
jad1217
May 20, 2006 05:16 PM
