suggested swap for a 91 dx
Old Mar 20, 2007 | 09:35 PM
liljohn's Avatar
Default suggested swap for a 91 dx
just wondering what kind of swap anyone would suggest for a 91 dx. that will be easy on the budget and reliable for a daily driver. Any help would be great.
Old Mar 21, 2007 | 11:12 AM
Powermidget's Avatar
Default RE: suggested swap for a 91 dx
B18a or B18a1....a1 has more hp but the B18a is obd0 like the dx so would be an easier swap...both are cheap....
also you could get a jdm d15b ...that is a really inexpesive swap for you cause you can use your tranny ect and it will give you a little more pep(vtec)
Old Mar 21, 2007 | 04:38 PM
liljohn's Avatar
Thanks for the info yeah I was kinda thinking along the lines of the d15b swap thats what I have swapped into my 92 cx. Although its non vtec.
Old Mar 21, 2007 | 04:58 PM
Thats why you want the jdm d15b it has vtec(there would not be much of a point to swap a non vtec d15 when you could just get a d16y8/z6)....there are some people on here with zc motors also...ive not got any real experience with them but there inexpensive and come in dohc & sohc....not a whole lot of aftermarket support from what i hear....hopefully someone sees this and put some more info about them on
Old Mar 21, 2007 | 05:01 PM
liljohn's Avatar
Alright thanks for the info it helps alot. Just wondering Ive been checking around and found some info on the zc swap and was wondering if it would b a worth while swap
Old Mar 21, 2007 | 05:45 PM
again zc motors not my forte but ive know some people that have had them....they are older motors which means they are not a wiring horror when swapping into your car (except youll have to wire for vtec)...dont plan on extensive aftermarket support...if you want to buiild a fast motor this might not be the best route...if you just want a qucker car and keep the motor stock short of i/h/e it would be a good bet i would assume
Old Mar 21, 2007 | 08:31 PM
impreCiV's Avatar
if it were me i would do a b16 gen 1, because its cheap and it has vtec, the zc doesnt. there plenty of aftermarket support for a b16 because they still make them just obd 2. has the most hp out of any of the above mentioned engines
Old Mar 21, 2007 | 11:20 PM
b8teen's Avatar
ive swapped a zc into my 91 hb. but if your looking for a legal swap. the zc wouldnt be a good idea. they dont have much aftermarket support.
Old Mar 22, 2007 | 01:14 AM
finalimpact's Avatar
sohc zc=d16a6 crx/civic si motor. everything is compatable
sohc zc vtec=d16z6, again everything is compatable.
jonnie_kurtzman
Jan 26, 2009 06:40 PM
taintedsaint
EG Swaps
May 16, 2008 04:46 AM
WhiteCivic15
Jul 7, 2006 03:17 PM
00civicEX_3
EK Swaps
Feb 26, 2006 11:08 PM
nemesis08
Jun 8, 2005 08:05 PM
