Tire\Tyres Rubbing on 95 Civc 4DR
Old Apr 1, 2007 | 07:36 AM
Biohazard's Avatar
Member
Default Tire\Tyres Rubbing on 95 Civc 4DR
Changed my stock 14 inch filthy wheels and tyres to some nice 16 Lo Pro Toyo's, now when I turn corners I get some "Nasty Rubbing" going on. Any advice? Ive been told stiffer suspension might reduce it. I've also been told it because of the offset of the wheel not the size!
Old Apr 1, 2007 | 09:48 AM
JerZy's Avatar
Default RE: Tire\Tyres Rubbing on 95 Civc 4DR
what is your stock size before and what size did you changed it to? Also, do you know both stock and aftermarket wheels offset?
Old Apr 3, 2007 | 07:16 AM
Biohazard's Avatar
Member
Alrighty, they were 185/65/14. The offset is different! the reason they are rubbing is because of the offset! I want to know what ideas you might have to reduce the rubbing.
Old Apr 3, 2007 | 07:35 AM
civicexracer's Avatar
rolling ur fenders might do it..
Old Apr 3, 2007 | 03:45 PM
JerZy's Avatar
Rolling Fender FTW!
Old Apr 6, 2007 | 08:32 AM
KarTuneMan's Avatar
Change the wheels....they DON'T fit. It's really that simple. There are no "fixes"
Old Apr 6, 2007 | 01:14 PM
4doorcivic9's Avatar
or raise your car up a titty bit, ha. what size tires are you running now? I have rota's I mean i know their 15's but im running 185/60/15 and mine is slammed and it doesn't rub or anything. Or yeah get better suspension, shocks, struts etc. w/a camber kit. expensive but it'll do that job.
Old Apr 6, 2007 | 01:30 PM
Fiasco's Avatar
had a similar problem.camber kit fixed it.
Old Apr 8, 2007 | 05:52 AM
Biohazard's Avatar
Member
Change the wheels?? So will you be sending me the cash to change them? I just bought them so I dont wanna hear any comments about "Changing Them" Cheers, Ive also been looking at a cheap way to panel beat the side walls out making the car look beefer
Old Apr 8, 2007 | 09:50 PM
Nail I3unny's Avatar
what is the offset on the aftermarket wheels?
if its too far from stock you will be better off selling them and buying ones that are made to fit your car. sorry...i know its not what you want to hear...but its the truth.
skeezix
Apr 1, 2009 11:06 AM
am_stpierre
Jun 22, 2008 09:24 AM
blackmetal619
13
Dec 11, 2007 10:35 PM
mombo
Oct 26, 2006 02:43 PM
THE_CRIPPLER
Sep 9, 2005 10:32 AM
