95 CIVIC WONT START...HELP!!!!!!!!
Old Jul 11, 2007 | 01:07 PM
PELUCAS's Avatar
Default 95 CIVIC WONT START...HELP!!!!!!!!
Hello everyone, My 95 honda civic wont start??????
for the past few month car felt or sounded???like a lot of gas was going thru had truble shifting from 1st to 2nd and finally last week car had a hard time starting for the last time, did try going arroud the blockwith no luck... .... when it comes to mechanic im a "0" would appreciate the help......thanks and keep up the good work.
Old Jul 11, 2007 | 01:33 PM
dfdon's Avatar
Default RE: 95 CIVIC WONT START...HELP!!!!!!!!
does the engine crank? we need some more details
Old Jul 11, 2007 | 01:43 PM
1997civic's Avatar
does it crank over? check to see if you are getting spark.
Old Jul 11, 2007 | 01:46 PM
I'm assuming the engine cranks but it doesn't fire. First it could be the main relay. Turn the key on but do not crank the engine. The "check engine" light should come on for about 2 seconds and go out. While the light is on you should hear the fuel pump under the back seat run and then stop.
Next take one of the spark plug wires off and push a screwdriver in where the spark plug would go then hold it near a metal surface. Have someone crank the engine. Sparks should jump. Be careful to hold only the insulated part of the wire or you will get shocked. It will not kill you but you should be sure there are no small children around to hear you swearing.
Ok if you have sparks, next check the fuel. Disconnect the fuel return hose which goes from the fuel pressure regulator on the fuel rail to a metal line on the driver's side at the firewall. Direct the hose into a container. Turn the key on but do not crank. Gasoline should come out for a couple of seconds and stop. Do this outside; you're expecting to see gas so be very careful of fire. Repeat this a few times and then look at your sample. Is it clean gas, or does it have water in it? If you don't get anything at all but the fuel pump is running (from the first test), the fuel filter may be clogged up.
Old Jul 11, 2007 | 08:19 PM
PELUCAS's Avatar
thank you all....to start .....yes enginecranks over....i will check relay....then fuel pump...after reading some of the post....it looks like it may be thefuel pump......thanks a lot and i will post more info a.s.a.p dont have internet at the moment so i have to go to my cousins to use it ......thanksssss
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
Brokedowncivic
Nov 10, 2005 08:06 PM
nic95civic
Oct 28, 2005 11:40 AM
MaD91cIv
Aug 8, 2005 02:40 PM
