at to mt conversion
Old Aug 11, 2007 | 01:21 AM
jesus95's Avatar
Default at to mt conversion
so i have a 95 del sol in automatic but i want to convert it to manual. what would i need to get to convert it all. i know clutch a new gear box and wiring harness but is there more i would need. this is my first conversion so everything you can give would help.
Old Aug 11, 2007 | 08:03 AM
Default RE: at to mt conversion
https://www.hondacivicforum.com/search.asp
... now that that's out of the way, off the top of my head, you'll need
-transmission
-master cylinder
-slave cylinder
-clutch
-pressure plate
-flywheel
-clutch pedal
-shift linkage
-shifter
-shift **** (if one didn't come with the shifter)
-shift boot (unless you're that cheap)
-manual ecu (I believe you can still use your auto ecu, but it will throw a cel... I've heard you can convert an auto ecu to work with a manual)
here's some links:
https://www.hondacivicforum.com/m_295187/tm.htm
http://www.honda-tech.com/zerothread?id=1255332
Old Aug 11, 2007 | 10:44 AM
jesus95's Avatar
oh man seriously thanks. this is what i was really looking for.hopefully i can have this done by the end of this year. thanks again
Old Aug 11, 2007 | 01:35 PM
ej6buddy's Avatar
just be sure to change the ecu, lol, s2000 knows all about it, an auto will work, but it will make it no more fun to drive than the automatic
NTX
Sep 18, 2004 01:54 PM
green98lxsedan
Sep 8, 2004 05:06 PM
civic1.5uk
Jul 30, 2004 11:57 AM
Drift queen
Jul 2, 2004 12:18 AM
chido
Jun 21, 2004 04:02 PM
