at to mt conversion
so i have a 95 del sol in automatic but i want to convert it to manual. what would i need to get to convert it all. i know clutch a new gear box and wiring harness but is there more i would need. this is my first conversion so everything you can give would help.
https://www.hondacivicforum.com/search.asp
... now that that's out of the way, off the top of my head, you'll need
-transmission
-master cylinder
-slave cylinder
-clutch
-pressure plate
-flywheel
-clutch pedal
-shift linkage
-shifter
-shift **** (if one didn't come with the shifter)
-shift boot (unless you're that cheap)
-manual ecu (I believe you can still use your auto ecu, but it will throw a cel... I've heard you can convert an auto ecu to work with a manual)
here's some links:
https://www.hondacivicforum.com/m_295187/tm.htm
http://www.honda-tech.com/zerothread?id=1255332
-transmission
-master cylinder
-slave cylinder
-clutch
-pressure plate
-flywheel
-clutch pedal
-shift linkage
-shifter
here's some links:
