wastegates?
Old Jun 22, 2004 | 04:59 PM
Lab Rat 21's Avatar
Default wastegates?
is a wastegate reliable enough to keep the boost consistantly at 6 pounds by itself or should i get a boost controller?im kinda runnning low on funds
Old Jun 23, 2004 | 08:51 AM
99civic_boosted's Avatar
Default RE: wastegates?
ORIGINAL: Lab Rat 21
The wastegate on a turbo will prevent it from going over 6 pounds. The boost controller will allow you to increase the boost to a higher number. If you do plan on increasing your boost above the 6 pounds set up by the manufacture, you will want to invest into boost guage and a blow off valve. The BOV will allow the pressure to escape and help save the wastegate/turbo.
The word "consistantly" does not really fit here. The turbo will be a the 6 pounds only when the gas pedal is floored and the RPM's are up and ... However it will not go over the 6 pounds unless the wastegate were to malfuntion. The BOV is more needed at higher boost however it is nice to have - just in case the wastegate were to malfuntion.
The boost controller goes in the vacuum line on the wastegate. limiting the amount of vacuum that goes to the wastegate. By doing this it allows you to build more boost before the wastegate will open. The WG still opens at the 6 pounds, just that the BC is preventing is from getting the 6 lbs. Kind of like pinching off a hose will still allow flow but at a lesser volume.
Man I think I getting confussed by reading what I wrote!
Old Jun 23, 2004 | 04:00 PM
Lab Rat 21's Avatar
even though i'm only running 6 lbs, i bought a bov and boost gauge. just wanted to make sure that wastegates were reliable enough to keep the boost at 6. dont want to blow my engine
Old Jun 23, 2004 | 04:04 PM
Lab Rat 21's Avatar
i thought that bov's release all of the boost when you let off the gas to protect the throttle body, since it closes. i didnt think it had anything to do with controlling pounds of boost
Old Jun 24, 2004 | 04:27 AM
polo708's Avatar
The wastegate lets the turbo reduce lag while preventing it from spinning too quickly at high RPM's. The wastegate is a valve that allows the exhaust to bypass the turbine blades. The wastegate senses the boost pressure... If the pressure gets too high then teh wastegate bypasses some of the exhaust around the turbine blades, allowing the blades to slow down.
The BOV is exactly how 99civic_boosted explained it... it allows excess pressure to escape saving your wastegate/turbo, its really only a problem with small turbos. it's pretty much for looks and sound on a large turbo.
IMO all turbos should have a BOV... they sound so sweet.
Old Jun 28, 2004 | 02:00 AM
iceman56's Avatar
hey lab rat, check out my post, i'm thinking about doing a turbo conversion on my cig. can you hook me up with some info?
Old Jun 28, 2004 | 08:45 PM
lilol89crx's Avatar
ORIGINAL: polo708
errrrrr [:'(] the wastegate opens up at a preset boost pressure, by doing this it doesnt allow the turbine to spin any faster therefore not creating any more boost than what the wastegate is set for. BOV basically saves the turbo in the long run, but also it decreases turbo backspin(slows the turbine down) which will cause a slight lagg condition between shifts.
silver wrench
Oct 7, 2008 01:50 PM
bcivic
May 3, 2008 04:00 PM
Littlehag
12
Dec 8, 2007 01:10 PM
D17Punk
17
Nov 3, 2007 03:12 PM
Swift
Feb 17, 2005 03:34 PM
