96 ex turbo setup
Old Nov 27, 2007 | 05:27 PM
lynch10586's Avatar
Default 96 ex turbo setup
hi i have a 96 d16 im lookin at a t25 turbo. i have about 155K on my car what should i be running for boost without blowin the motor and how should i go about tuneing it
Old Nov 27, 2007 | 05:29 PM
Default RE: 96 ex turbo setup
leave it internally gated at the 8 PSI, get a compression test on your engine to make sure all is well, and for tuning, if you are running a mellow T25 at a low PSI, looking for numbers right around 200hp, Crome would be fine for tuning. Just convert back to OBD1 and chip/tune your ECU at a professional tuner, preferably a dyno. As for more info about everything you need, read ALL the stickies at the top of the Nitrous/Turbo/Supercharger section, they're very insightful
Old Nov 27, 2007 | 09:09 PM
Littlehag's Avatar
ORIGINAL: FlipHKD720
if you leave it gated at 8psi you should be fine asfar asnot blowing your engine. Before you even consider a turbo, make sure you do a compression test like flip said.
Old Nov 29, 2007 | 06:13 PM
johnny's Avatar
You could blow your engine at 2 PSI. It's all in how it's tuned. I would leave it internally gated. T25's dont have much topend.
You should start by running a Leakdown and Compression test.
Is your EX Canadian? (D16Y7) Is that 155Km? Or Miles?
Mistaashby12
15
Jul 16, 2008 11:30 PM
johnwohl
Jan 9, 2008 07:34 PM
98 EJ8
May 21, 2006 04:38 PM
94TurboCivicEX
Mar 16, 2006 01:30 PM
97civicturbo
Jan 9, 2006 10:35 PM
