Tranny bearing noise....
Old Dec 19, 2007 | 12:18 AM
digimon916's Avatar
Default Tranny bearing noise....
my trannys making a noise, but only when it is in gear (noise stops when i press the clutch [disengaged]). i also bought a stage 1 clutch but do not want to install it yet. it also came with a bearing, the shift bearing. could that beaing be the probelm? or do you guys think its something with the tranny itself? cuz if its the bearing i have, then i could do it myself, but im not sure whats wrong. gimme your input. thanks...
Old Dec 19, 2007 | 01:25 AM
Default RE: Tranny bearing noise....
well it could be the guide bearing or throw out bearing... only way to find out is just pull your tranny and slap those bearings...
ya dont have to pull the clutch to change the bearings...
Old Dec 22, 2007 | 11:52 AM
Lickmyballsdsm's Avatar
no ive had this problem before its the bearings on the main input shaft in the tranny start lookin for a tranny now, because parts alone for the bearings are $350 and not to mention the insane labor charges a tranny shop will charge you
Old Dec 22, 2007 | 07:38 PM
digimon916's Avatar
yeh, i just thought about buying a new tranny because they charge ha lotfor taking the tranny apart and putting it back...
u know how much it is for a 97 EK A000 manualtranny?
Old Dec 29, 2007 | 12:28 PM
if its a sohc motor any manual tranny from 1992 up civic will work there all the same
Old Dec 29, 2007 | 08:28 PM
Hoffmann21's Avatar
Input Shaft.
my car has the same thing.
Old Jan 13, 2008 | 10:52 AM
reconstyle's Avatar
ORIGINAL: Lickmyballsdsm
350 bucks?
How do you figure?
rc2904
Dec 23, 2013 09:49 AM
northwoods
Nov 10, 2012 08:26 PM
ether.real
Oct 7, 2009 06:50 PM
logigamer
Jul 4, 2008 03:17 PM
TITIKO
Jan 10, 2005 10:23 PM
