Will this work?
Old Feb 9, 2008 | 08:33 PM
EJ8_Man's Avatar
Default Will this work?
Hi Guys,
I need your feedback on an idea. Today I pulled a set of rear brake assemblies off an Integra. I am swapping out the drums on my Civic EX. I pulled everything apart to inspect the parts for damage and I came across a big problem. As you can see in the picture a flange bolt was damaged, and the threads it would go into are also damaged. The upper arm bracket was also bent, I hammered it back into place, and it's strait again. My thought is to drill out the bad threads and make it a through hole. Then put a bolt through it and use a nut as a fastener to replace the damaged portion. I'll have to find a bolt long enough to do this, and make sure it's the proper steel grade for the job.
I want your opinions, do you think my idea will be sufficient to hold things together? If you have any suggestions I'd appreciate it. Thanks for your help.
[IMG]local://upfiles/28319/9866FA3A8FCF4237AD414C8F05086391.jpg[/IMG]
x1mpr0x
Sep 4, 2009 07:44 PM
muuurph
19
Oct 25, 2008 09:09 AM
importcivicus
Mar 15, 2006 08:28 PM
lilol89crx
Jul 29, 2004 06:56 PM
drrocket0302
Jul 20, 2004 11:30 PM
