Mini V-Tec
Old Feb 27, 2008 | 05:06 PM
95DXcIvIc's Avatar
Default Mini V-Tec
i have a 95 dx 1.5. i heard something about a mini V-tec for non v-tec motors. i was just wondering if there was such a thing and if so how do you go about doing it?
Old Feb 27, 2008 | 05:09 PM
Default RE: Mini V-Tec
what you're thinking of is a mini-me swap. It's a head swap where you take a vtec engine's head and put it on a non-vtec block, and it's usually good for a (relatively) cheap 20 horsepower or so. If you do a search for "mini me", I'm sure there will be a ton of info.
Welcome to the forums, by the way
Old Feb 27, 2008 | 07:10 PM
koots's Avatar
Heads your gonna want to look for are the D16Z6 SOHC head/manifolds and vtec solenoid. than your gonna need an ECM so that you can use the vtec
or you can get a D16Y8 head from the 96-2000 civics and get the same as mentioned above.
Old Feb 28, 2008 | 12:22 PM
ItshYaBoyTricky's Avatar
Now thats some great info there and i would love to get that cuz mines isnt vtec either so i would get this, does anyone know how much it would be?
Old Feb 28, 2008 | 01:07 PM
ic892003's Avatar
type in mini, you cna put either a y8 head or a z6 head on your current non vtec block, you will also need to wire up the vtec solenoid and ai would suggest replacing the timing belt and other parts as well. i was oging to do the same swap but in my opinion you would be better off going with a full motor swap
Old Feb 29, 2008 | 04:37 AM
knobber295's Avatar
ya do you know which head is more efficient, the d16z6 or the d16y8 head.
Old Mar 16, 2008 | 07:26 AM
s2000gtx's Avatar
The Y8 is newer than the Z6 so it all depends. to me z6 would fit u best becasue u have an obd1 car and the z6 is obd1. y8 is obd2 so u will need the conversion/piggyback or rewire the whole car
HondaEGcoupe
Aug 9, 2009 10:12 AM
point break 92
EG Swaps
Feb 22, 2008 04:37 AM
Kenneth Ames
20
Feb 17, 2007 10:39 AM
AOL.COM
Apr 24, 2005 12:07 AM
GSXF
Feb 23, 2005 09:45 PM
