Syncro Problem - Best Plan of Action??
Old Dec 3, 2008 | 05:16 PM
ltkenbo's Avatar
Default Syncro Problem - Best Plan of Action??
So apparently my 3rd gear syncro is bad because when I shift into 3rd it will often pop out (not engage right) when I let out the clutch. I have known this for a couple months cause its been going on for a year or so.
Anyways I have a 99 EX, what would be my best plan of action to fix this? Have the syncro replaced? Or get a used transmission somewhere and replace it myself? I'm guessing that the syncro is pretty difficult to replace so I'd probably have a mechanic do that, but I could to the transmission myself. So how much would having the syncro replaced cost?? What do you think I should do, the problem is quite annoying and needs to be fixed.
Old Dec 7, 2008 | 09:53 PM
riceburner700's Avatar
its not the syncro with that d-series tranny i bet the CS bearing under the shaft assembly has moved outward. very common on the d-series. also people think its the syncros when they start grinding third gear but its not, the shift forks get warn down or break and need replaced.
Old Dec 16, 2008 | 02:56 PM
ltkenbo's Avatar
Well its rough and it doesn't engage properly. So should I get it fixed or get a new transmission?
Old Dec 16, 2008 | 05:54 PM
it really depends on how comfortable you are with taking a tranny apart. you can pick up another d-series tranny for $200-$300
Old Dec 16, 2008 | 11:35 PM
ltkenbo's Avatar
Well I'm not very familiar with the transmission internals and wouldn't know if it was bad or not so I'd probably pay someone else to fix it or if I replace it I would do it myself. How do I know if the transmission is the right one, I know some will work but I want the right one, since I have a vtec motor. I've got a 99 civic EX so whichever one goes with the D16Y8 motor. How do I know if its the right one?
Old Dec 17, 2008 | 08:19 AM
there is a code stamped onto the transmission that indicated which motor it came from it will say P40/B000 by the drain plug
ic892003
Nov 29, 2006 06:53 PM
El Blanco REX_DELETEDBYREQUEST
Sep 2, 2006 07:48 PM
joshsss
Aug 3, 2006 09:50 AM
StifflersMom
May 30, 2006 08:25 AM
91crx_87
Sep 25, 2005 11:38 PM
