syncro again! pls advice
Old Aug 1, 2006 | 12:08 PM
joshsss's Avatar
Default syncro again! pls advice
dear all,
I have a small problem, i do not change gears properly. As a result, my syncros are gone (fifth gear slipping and crrrrk sound when whacking). Anyways, since i have to change them, i would like to know if after-market ones are any good such as the carbon coated syncros or the original ones are good enough?
I'm running a very stock set-up now but have plans to beef it up very soon(B18, track). While i'm at it, should i perhaps do up my gear box too? I drive an eg9 and i don't suspect the previous owner gave much love and attention to the transmission.
once again, thank you all for the much appreciated advice.
_________________
vtec for life.
Old Aug 2, 2006 | 11:28 PM
killajay's Avatar
Default RE: syncro again! pls advice
...... Okay.. I will try to be nice.. Number 1, Before spending the moeny on syncro's.. Learn to drive better before you mess up the new syncros.. Number 2, learn to race before the B18 swap.. Number 3 the stock syncros will be fine, when you do the swap you wont be using Dseries tranny anyways so it would not be wroth spending a great deal of money on the syncro's.. thats all i have.. Good luck
Old Aug 3, 2006 | 09:44 AM
joshsss's Avatar
thanks dude.
Old Aug 3, 2006 | 09:50 AM
AgentofDarkness's Avatar
Number 1 is learn to drive better, if you don't drive correctly your gonna be going to synchros like water. If you car has a D-series engine, you cannot mate a B18 to the D-series trans. You will need to get a B-series trans. So if ur getting a swap, don't bother fixing the trans just drive better.
turbo speeder
20
Jan 22, 2009 02:38 PM
ic892003
Nov 29, 2006 06:53 PM
El Blanco REX_DELETEDBYREQUEST
Sep 2, 2006 07:48 PM
HondaBlue
Mar 27, 2006 04:25 PM
91crx_87
Sep 25, 2005 11:38 PM
