Installing Lip, Question (sorry)...
Old Mar 30, 2009 | 04:34 PM
JizzleCX's Avatar
Default Installing Lip, Question (sorry)...
I looked through a few pages of searches so sorry, but I just have a few quick questions about installing my new type R lip on my 96 ek.
1)the top piece is supposed to sit on the bottom of the lower grill, not be completley under the bumper right?
2) if i just put to self tapping screws in each side inside the wheel well attached to the bumper, with that piece on the lower grill it should hold no problem, correct? or do I need to 3m tape the sides to the bootom of the bumper?
Thanks in advance.
Old Mar 30, 2009 | 08:10 PM
yes and yes it should hold. if you are worried about it falling off then you can add some 3m double sided tape between the lip and the lower grill portion
Old Mar 30, 2009 | 08:19 PM
ej6buddy's Avatar
On your generation, all that is required is a few 6 inch strips of double-sided (foam or not) tape. Then just some stainless self tapping screws for the rear of the lip. Some people use a bolted setup to slightly deter theft.
Old Mar 30, 2009 | 08:49 PM
JizzleCX's Avatar
alright well thanks guys, gonna put it on tomorrow after work black housing headlights are on the way to go with the new 8000k hids
Old Mar 30, 2009 | 08:51 PM
ej6buddy's Avatar
is this going to be a retrofit with blocking plates? b/c it's kinda blinding in factory style non-hid headlight units unless you have a proper hid setup with auto leveling devices.
Old Apr 3, 2009 | 11:58 AM
JizzleCX's Avatar
no retrofit, just gunna put em in and adjust them manually
01silverbullet
May 24, 2008 04:44 PM
phan10m
May 4, 2007 08:19 AM
Onebadgtx
Mar 14, 2007 08:54 PM
xkeseriesi
Feb 4, 2007 11:34 AM
fdjizm
Aug 5, 2006 09:59 AM
