94 civic ex trans
Old Jun 2, 2009 | 01:23 PM
candyman420's Avatar
Default 94 civic ex trans
so my girl friends 94 civic ex is having some problems with her tranny i think... the short drave axle is lose and raddles alot.... it seems that where the axle splines into the tranny is loose is this a common problem and how do i fix it?
Old Jun 3, 2009 | 04:38 PM
I'm not entirely sure, but wouldn't that mean a bad CV joint? You probably need to just replace the axle.
Old Jun 3, 2009 | 08:05 PM
i did replace the axle but it is still rattleing around where it splines into the trans....
Old Jun 3, 2009 | 08:09 PM
Is transmission fluid leaking from the differential where the axle splines insert?
Old Jun 3, 2009 | 08:22 PM
not when the axle is in but when i take the axle out its kinda grey like water or somthing might be getting in.... the car is flayless on leaks... no oil or anything else leakin
Old Jun 3, 2009 | 08:25 PM
Have you installed the correct axle for the engine? It shouldn't be loose. When grab the axle firmly, where is the free play?
Old Jun 3, 2009 | 08:29 PM
im 100% positive its the right axle..... when u grab the axle on the arm? the whole things shakes... its the only thing loose on the whole car that i can think of that would rattle every time i hit a bump.....i grab the axle on my crx or my old 94 civic the axle didnt shake like this one....
yetti8
Oct 1, 2007 10:26 AM
bonzitre
Jan 21, 2007 08:51 PM
Lordnismo
Sep 26, 2006 03:07 AM
jtshop
Nov 22, 2004 10:18 AM
