help! turbo smoking?
Old Nov 2, 2009 | 07:39 AM
johnjohnjr's Avatar
Default help! turbo smoking?
hey im new to this forum thing i just need help on my civic. it is a 96 coupe with a 1.6 t3 t4 turbo. i recently put it on fri and it smokes bad! out threw the exhaust side everytime i give it gas its practicly building up and leaking. can anyone help?
Old Nov 2, 2009 | 07:58 AM
bad turbo oil seal, u have a bad turbo.
Old Nov 2, 2009 | 12:04 PM
johnjohnjr's Avatar
Well what if I don't have a oil restrictor
Old Nov 2, 2009 | 03:42 PM
JCruz's Avatar
your turbo goes bad if you dont have one
Old Nov 3, 2009 | 03:55 AM
croninc's Avatar
rebuild time!!!
where did you get the turbo from?
Old Nov 3, 2009 | 05:35 AM
also do you even know about turbo's?
do you have a turbo timer?
do you let your car run for 2-3 mins after driving it, before you turn it off?
Old Nov 3, 2009 | 06:20 AM
hamorhead's Avatar
pssh thats for **** that like to keep they're turbo's working
Old Nov 3, 2009 | 07:27 PM
2-3 minutes is a bit much, 45 sec - a min should be fine....
a turbo timer will help with this though, although you can do it yourself without, but sounds like you need:
http://www.gpopshop.com/garrettt3kits.html
Old Nov 5, 2009 | 07:05 AM
Wing_Zero's Avatar
my friend your turbo is bad.
Old Nov 9, 2009 | 05:19 AM
xero_xero's Avatar
yeah, turbos are a pain if you dont paintain them and run them properly... hell if you dont change your oil enough. there is a banks system for big trucks that keeps the motor running until the turbo properly cools down... turbo timer included... nearly noob proof as long as a pro installs it...
Coking turbos is expensive.. change your damn oil.
1992 civic driver
May 20, 2010 06:40 PM
tombakers
Sep 16, 2008 08:31 AM
MIkeyP
Aug 23, 2007 01:39 PM
BuzzOrHowl
Jan 9, 2007 08:44 PM
billybobzia
Jul 8, 2004 09:03 PM
